Greška C42,
Autor Stjepko, Svibanj 26, 2021, 10:56:57
Greška C42,odakle počet tražit. Da ne raskopavam sve.
Citat: Stjepko  u Svibanj 26, 2021, 10:56:57
Na Stromu il na toj tvojoj pili  :huh:
C42 je nešto oko prekidača paljenja..startera ili ti ga Kill switcha
Na bivšoj somari.Fala za info.
Citat: Stjepko  u Svibanj 26, 2021, 11:37:12
Može biti i prekidač nogara i na ručici kvačila
U biti sve je to povezano s kill svitchem  :thumbup:
Da. Nego kad će mo se naći i killswićnuti se
Citat: Stjepko  u Svibanj 26, 2021, 11:56:53
Lajkam i potpisujem
C00 No error
C11 Camshaft Position Sensor (CMPS) - 1000 Only
C12 Crankshaft Position Sensor (CKPS)
C13 Intake Air Pressure Sensor (IAPS)
C14 Throttle Position Sensor
C15 Engine Coolant Temp. Sensor (ECTS)
C16 Vehicle Speed Sensor Circuit (Front) Malfunction
C17 Intake Air Pressure Sensor (IAPS) - 07 & Up 650 Only
C21 Intake Air Temp. Sensor (IATS)
C22 Atmospheric Pressure Sensor (APS) - 1000 Only
C23 Tip Over Sensor (TOS)
C24 Ignition Signal #1 (Front Coil)
C25 Ignition Signal #2 (Rear Coil)
C26 Ignition System #1 (Side) Malfunction
C27 Ignition System #2 (Side) Malfunction
C28 Secondary Throttle Valve Actuator (STVA)
C29 Secondary Throttle Position Sensor (STPS)
C31 Gear Position Sensor (GPS)
C32 Injector Signal #1 ( Front)
C33 Injector Signal #2 (Rear)
C40 ISC Valve - 07 & Up 650 Only
C41 Fuel Pump Control System (Fuel Pump Relay)
C42 Ignition Switch Signal (Anti-Theft)
C44 Heated Oxygen Sensor (HO2S)
C45 May be the same as C44 on earlier models or rear ABS sensor on later models (not well documented)
C46 EXCVA Sensor Circuit Malfunction
C49 PAIR Control Solenoid Valve
C60 Cooling fan relay circuit malfunction
C62 EVAP system purge control solenoid valve circuit malfunction
C64 HO2 Sensor #1 Heater Circuit Malfunction
C65 Idle speed malfunction (can be caused by any fault that takes the idle speed out of range, TPS and GPS faults for example)
C91 Vehicle Speed Sensor Circuit (Rear) Malfunction
Nadam se uskoro..6. Mj.
Poslano sa mog SM-G935F koristeći Tapatalk
Navijam i jedva čekam grešku 42 da se killswićamo zajedno :ooda: :thumbup:. Pri tom ne mislim na ništa pedersko (zle duše mogu da mi puše :tongue:), već na kvalitetno druženje s puknutom ekipom :want: :beer: :beer:.
Meni gorilo skroz c00
Citat: Stjepko  u Svibanj 26, 2021, 14:28:22
Tebi je odavno 00
Ozbiljno govorim, skroz mi se to palilo i rijetko se kad gasilo na satu.
Citat: munja  u Svibanj 26, 2021, 14:14:46
..to te upozorava da moraš pišati  :shhh:
Citat: keko  u Svibanj 27, 2021, 11:58:01
Ne nego stati na pivo.Jbga znaš da nije nikakva greška a zivcira bzvze, nisam vidio koliko je sati oa sam uvijek kasnio kući.
