Autor Tema: Metzeler Tourance Next  (Posjeta: 18793 vremena)
Offline tibertov
  • Postova: 5048
  • Abcd
« u: Kolovoz 10, 2017, 16:11:42 »
The new Metzeler Tourance NEXT are enduro street tires that dare you to challenge any weather condition and any road. This 90/10 tire represents the latest generation of enduro street tires, featuring new compounds, profiles, structure and tread pattern for unmatched levels of stability, safety on wet and mileage. Rear tires are now dual compound, derived from Metzeler's Z8 Interact tires focused on increasing wet performance and mileage. The rear tire shoulder compounds are 100% Silica that guarantees an excellent chemical grip on wet surfaces and provides great confidence and feel. Front tires also feature a high silica content for improved handling and faster warm up.
Features:
Improved wet grip and stabilityImproved mileage over previous Tourance EXP tiresFeatures Metzeler's Zero Degree Steel Radial technologyMAW (Metzeler Advance Winding) system optimizes the spacing between the cords of the Zero Degree steel beltDifferentiated groove layout and shapeImproved water evacuation as the compound is always in contact with the roadDual Compound rear sizesCenter, harder compound is 40-45mm wide depending on tire sizeRear tires feature Silica content of 50% in center compound specifically designed to optimize mileage and stability at high speeds and fully loadedShoulder compounds are 100% Silica to guaranty an excellent chemical grip on wet surfaces Rear tires feature Metzeler Interact technology with three zones of variable tension belt layout, similar to the Roadtec Z8 InteractFront tires are single compoundFront tires also feature a high Silica content (over 50%) and uses new polymers and resins to provide improved handling and grip with fast warm upNew, innovative high stiffness structure for a more sportbike-like tire behaviorIdeal choice for the latest generation Adventure touring bikes
Offline tonciv666
  • Postova: 934
Odg: Metzeler Tourance Next
« Odgovori #1 u: Kolovoz 10, 2017, 16:31:34 »
Odlična guma,u mene drugi set
Offline Macak
  • Punopravni član
  • Postova: 278
  • born to be diferent
  • Motor: v-strom dl 650A L4
  • Motor: apn 4 , oldajmer
  • Motor: Suzuki GS 500 F ženin
« Odgovori #2 u: Kolovoz 10, 2017, 17:54:58 »
Napravio sa njima 11 tkm gume su vrhunske i dan danas,,,,,, :thumbup:
0981890220
Offline bajki
  • Global Moderator
  • Postova: 1813
  • Motor: DL 1000A
« Odgovori #3 u: Kolovoz 11, 2017, 07:00:30 »
Ja sam isto prezadovoljan ovim gumama! :bravo:
Offline Peco
  • Punopravni član
  • Postova: 239
« Odgovori #4 u: Kolovoz 11, 2017, 07:21:37 »
Proba..dosad meni najbolje
Poslano sa mog SM-T585 koristeći Tapatalk
Offline Suki
  • Postova: 6041
  • ...go anywhere...
  • Motor: Honda CRF 1000L Africa Twin
« Odgovori #5 u: Kolovoz 11, 2017, 07:36:33 »
Imao ih poslije originalnih Bridgstonki. Nebo i zemlja :thumbup:.
Offline željko
  • Postova: 560
  • Motor: vstrom dl 650 - k7
« Odgovori #6 u: Kolovoz 11, 2017, 10:37:39 »
 Na Motorrad-ovom usporednom testu optimalnim performansama odnijela je pobjedu ispred konkurencije: Michelin Anakee 3, Bridgestone Battle Wing 501/502, Continental TrailAttack 2, Dunlop Trailmax TR91 i Pirelli Scorpion Trail. Sve gume, u dimenzijama 110/80 R19 i 150/70 R17 bile su montirane na šest Triumph Tiger Explorera.
Offline Toni
  • Punopravni član
  • Postova: 360
  • Motor: Africa Twin CRF1000L
« Odgovori #7 u: Rujan 03, 2017, 13:04:19 »
Mene ova guma interesira za afriku. Za sada imam conty atack 2 a sljedece ako vidim da po kisi nije dobra bi moga te mecelerke uzet.
Nije mi nista.
Offline sasaa
  • Postova: 1882
  • Motor: R1200GS Triple black
  • Motor: R65 '82 caffe
« Odgovori #8 u: Rujan 04, 2017, 00:45:36 »
I meni jedna od opcija za sljedeci set.. probat nesto drugo za iducu sezonu - nakon Anakee3.
Offline Fantom
  • Punopravni član
  • Postova: 289
« Odgovori #9 u: Rujan 06, 2017, 13:15:31 »
I na mom je motoru od pocetka ove sezone. Pada u krivinu i na samu pomisao.. Ubi me kisno ljeto nisam okrenuo jedva par djirova.  :'(
Offline Bagy
  • Postova: 2849
  • Motor: Mali garavi 105.000 km
« Odgovori #10 u: Rujan 06, 2017, 14:02:01 »
Koje kišno ljeto, pa nije kiše bilo 2 mjeseca! ;)
...nema Stroma - do malog Stroma! Dok se ne uzme nešto jače! 😜
Offline Suki
  • Postova: 6041
  • ...go anywhere...
« Odgovori #11 u: Rujan 06, 2017, 14:06:04 »
 :ooda:
Odlična guma :thumbup:.
Offline Fantom
  • Punopravni član
  • Postova: 289
« Odgovori #12 u: Rujan 06, 2017, 17:28:01 »
Ostavio kisu i nakon 4 sedmice odmora opet zateknem oblacinu i kisu u Danskoj  :'(
Online agolac
  • Administrator
  • Postova: 5661
  • Neprilagođen...
  • Motor: DL1000 K6 60.000 km
  • Motor: DL650A K7 53.000 km
« Odgovori #13 u: Rujan 06, 2017, 17:29:21 »
Proći će ti život u magli i kiši. Na kraju se čovjek zapita da li stvarno vrijedi? :)
Deus Ex Machina
Offline Fantom
  • Punopravni član
  • Postova: 289
« Odgovori #14 u: Rujan 06, 2017, 17:37:15 »
Ovo ljeto je van serijsko svugdje. Balkan izgorio, a ovdje jedva zapalis cigaru na otvorenom  :smijeh:
