Tempomat najjeftiniji
Autor zander, Veljača 06, 2018, 08:47:33
Danijel,
How the Murphs CCS-100 Cruise Works
The cruise monitors engine RPM through the blue wire connected to your
tachometer or coil wire. Without a tachometer signal the cruise won't work.
The Cruise servo cable uses engine vacuum to move your throttle. Without
engine vacuum the cruise won't work.
The purple or brake light wire allows the cruise to turn on and shuts the
cruise off when you apply the brakes. If the purple brake wire is not
connected correctly the cruise either won't turn on or won't shut off. You
can always shut the cruise off by turning the cruise off at the control
keypad.
To summarize, you need a tachometer signal to the blue wire, engine
vacuum connected to the servo, and the purple brake wire connected
correctly for the cruise to work. If you don't have all three, the cruise won't
work.
Yes, I really planed to drive my DL1000 K7 until the end of eternity....
Sad mu to prevedi na talijanski
Citat: Lavandić  u Veljača 06, 2018, 21:06:23
To je još super, zamisli da držiš cicu a netko drugi jebe?!?
To mi je ne zamislio  :smijeh:
damjandugi
Citat: damjandugi  u Veljača 07, 2018, 16:08:26
Evo jedne vrlo jeftine verzije cruise co :buahaha:ntrola.
https://www.wunderlich.de/shop/en/cruise-control-26160-102-1.html
E tu ostaje gas u poziciji kojoj si narihto,  pa čak i kad digneš ruku sa upravljača!
Citat: zander  u Veljača 06, 2018, 16:27:08
U zadnje vreme se bavim Aliexpresom jer sam shvatio da se 70% robe po zapadnim zemljama pravi u Kini a zapadnjaci postave cenu x10 i prodaju svima ukljucujuci i nas.... A razlike nema, isto je to ljudi....pojedini predmeti su toliko jeftini da je greh ne kupiti ih, pa i ako ne valjaju bacis tih evrodva...
:ebudale: I ja sam im se namamurao na kosti.
Neki dan mi stigle blatarice za auto. U VW za iste takve traze 200 eura, a ja ih platio na aliju 23 eura + besplatna posiljka dostava 35 dana ili ih dobijas dzaba. Jos mi na moj zahtjev prodavac napisao vrijednost paketa na 5 eura kako nebi platio porez koji se za proizvode van EU placa preko 10 eura vrijednosti.
Sad cekam da mi stigne naslonjac za ruku, magnetni drzac za mobilni telefon i gomila zajebancija za ribolov.
Dosta su popravili kvalitetu izrade i Aliexpress svaki put vrati novac kada produkt nije kao u opisu, nestigne do navedenog vremena i sl.
Pametna investicija a nije veliki gubitak ako zajebu....samo napred :thumbup:
