V-Strom SX 250 [2022-xxxx]
Autor Mrki, Travanj 27, 2022, 21:31:58
Novi model..
Suzuki V-Strom SX 250, a lightweight, versatile crossover. Suzuki's specialists were clearly inspired by the appearance of the V-Strom 650 XT, and borrowed some off-road features from its older brother: 19/17-inch wheels with dual-purpose tires and 205 mm of ground clearance. The motorcycle is equipped with a 249 cc single-cylinder 26.5 liter engine. Also worth noting 2-channel ABS, a USB connector for recharging gadgets,  hand protection, and a dashboard with an SRC system that supports phone call and SMS notifications, as well as simple turn-by-turn navigation.
Engine CC:   249 cc
No Of Cylinder:   1
Max Power:   26 bhp @ 9300 rpm
Max Torque   : 22.2 Nm @ 7300 rpm
Valves Per Cylinder   :4
Fuel Delivery:   Fuel Injection
Cooling System:   Oil Cooled
Starting Mechanism:   Self Start
Kerb Weight:   167 kg
Length: 2180 mm
Width   : 880 mm
Height   : 1355 mm
Wheelbase   : 1440 mm
Ground Clearance:    205 mm
Seat Height   : 835 mm
Front Tyre   :100/90-19M/C 57S, tubeless
Rear Tyre:   140/70-17M/C 66S, tubeless
Nekakav jadni pokušaj kopiranja honde crf 250..nažalost neuspio..ovo nit smrdi nit miriši..nit za cestu nit za teren  :bzvz:
Vidio to,mene brine da nema ni najave novega malega...čekam,sutra bi ga kupil  :misli:
Aj hvala Bogu prodali su sve retrovizore
Poslano sa mog YAL-L21 koristeći Tapatalk
Boja taman za Glovo
Citat: Ćoso  u Travanj 27, 2022, 21:50:21
Boja taman za Glovo
ne znam što vi imate međ sobom..al Keko je moje veliko kolegstvo i tužan sam kad ga neko sprda  :'(
Treba uzeti u obzir da je ovo model koji je prvenstveno napravljen za Indijsko tržište..
Citat: zorro  u Travanj 27, 2022, 21:56:18
stvarno nije fer....  :-X
Citat: Grba  u Travanj 27, 2022, 21:44:49
Sutra bi Stroma kupil, a hvalimo i vozimo BMWeja!  :belj:
O ukusima ne treba raspravljati, meni je ovaj na oko lepši i od malog i od velikog, a kanarinac boja mi se sviđa još od Kekinog, uočljiv je što je bezbednosno po meni vrlo bitno.
Moguće da je ovo najava za novog malog, bumo vidli :) Instrument ploča bi mogla biti ovakva kod 650cc
Citat: Danijel 23  u Travanj 28, 2022, 07:58:40
Strom je jedan jedini i moj,i da kupil ga budem i 3.put.
Niš ne hvalim,samo sam svoje dojmove stavil.
Bmw je službeni a svako takvo vozili je dobro,a ovaj Gs i sliči Renaultu Clio na dva kotača.
Ciao  :bzvz:
Branac
Citat: Saxi  u Travanj 28, 2022, 08:55:22
Potpisujem sve, ovaj žućo je k'o stvoren za one >70 g.  ;) ... ps. kolegstvo moje, bez zamjere  :-*
