TIGER EXPLORER 1200 XCA
Autor Mrki, Kolovoz 04, 2017, 18:53:49
ENGINE AND TRANSMISSION
Type:   Liquid-cooled, 12 valve, DOHC, in-line 3-cylinder
Capacity:   1215cc
Bore Stroke:   85 mm / 71.4mm
Compression:   11.0:1
Max Power EC:   139 PS/137 Bhp (102 kW) @ 9,300 rpm
Max Torque EC:   123 Nm @ 6,200 rpm
System:   Ride by Wire, fuel injection
Exhaust:   Stainless steel 3 into 1 header system, side mounted stainless steel silencer
Final drive:   Shaft drive
Clutch:   Wet, multi-plate hydraulically operated, torque assist
Gearbox:   6-speed
CHASSIS
Frame:   Tubular steel trellis frame
Swingarm:   Single-sided, cast aluminium alloy with shaft drive
Front Wheels:   32 spoke, aluminium rim, for tubeless tyres, 19 x 3.0in
Rear Wheels:   32 spoke, aluminium rim, for tubeless tyres, 17 x 4.5in
Front Tyres:   120/70 R19
Rear Tyres:   170/60 R17
Front Suspension:   WP 48mm upside down forks, electronically adjustable damping, 190mm travel.
Rear Suspension:   WP monoshock, electronically adjustable semi active damping, 193mm wheel travel. Automatic preload adjustment.
Brakes Front:   Twin 305 mm floating discs, radially mounted monobloc Brembo calipers, 4-piston, switchable ABS
Brakes Rear:   Single 282mm disc, Nissin 2 piston sliding caliper, switchable ABS
DIMENSIONS AND WEIGHTS
Width Handlebars   830 mm (930 mm with hand guards)
Height: Without Mirror   1470 mm (1540 mm with higher screen position)
Seat Height:   837-857 mm
Wheelbase:   1520 mm
Rake:   23.1˚
Trail:    99.2 mm
Dry Weight:   258 Kg
Tank Capacity:   20 Litres
Sa cestovnim bratom..
Mmmmm, bio tiha patnja, ali GS pretego ;)
..to mi je i dalje najljepši motor u klasi  :ooda:
Citat: keko  u Kolovoz 04, 2017, 23:22:45
zeleni  ;)
Najskuplji motor u HR od tih velikih endure...
Citat: JZ  u Kolovoz 05, 2017, 08:51:38
Kako mislis?
Zar bmw, dukac i ktm SA nisu skuplji?
Poslano sa mog Y6 koristeći Tapatalk
Igor Mihajlik
Odlican motor, fantastičan za vozit, skup, u Sloveniji slaba servis a mreža. Meni isto izgledom jedan najlepsih u klasi.
Lado je moj idol
Moćno izgleda, čak mu i ta bijela boja paše!  :thumbup:
Mnogo preskupo, ostajem na Kenji!  :)
Osim skupoće, da li postoje veće zamjerke (da li je netko čuo/pročitao o nekim učestalim kvarovima i slično)?
Servisna mreža? U Zagrebu to Viktor nabavlja, pa vjerujem da ima i servis
Aaaaa dvoumiš se, ili GSA ili Tigera :thumbup: Slatke muke ;)
Koji ce ti kuki taj triumph, daj uzmi gs... U krdu je toplije :smijeh
P.s. gsa, a ne gs
Citat: tibertov  u Studeni 27, 2017, 17:38:12
P.s. gsa, a ne gs
Koji će ti kuki GSA. Prodaj to i uzmi Triumph  ;)
