Bilo to od 2011 do 2014....znaci prastara vest....imao sam model 2011 i nije bilo takvog kvara... :thumbup:
Citat: Paf  u Veljača 24, 2021, 11:19:33
    Evo pocea im je opoziv,jer im pumpe pustaju gorivo...nisam nikad cuo za Stroma neki opoziv ...  :)
                                      https://www.advpulse.com/adv-news/bmw-issues-more-recalls-on-r1200gs-other-models-for-fuel-leaks/
Bitno je da ti nisi cuo
https://suzukicycles.com/recalls
This Notice Applies to Your Motorcycle VIN: JS1VP56A_XXXXXXXX
May 26, 2014
Dear Suzuki Owner:
This notice is sent to you in accordance with the National Traffic and Motor Vehicle Safety Act. Suzuki Motor Corporation has
decided that a defect which relates to motor vehicle safety exists in 2014 DL650A V-Strom motorcycles.
What is the problem?
On some 2014 Suzuki DL650A V-Strom motorcycles, a link on the drive chain may not have been riveted properly. If
a link becomes disconnected, the drive chain can come off the sprockets while the motorcycle is being operated and
engine power will not be transmitted to the rear wheel. This can result in loss of control of the motorcycle, and can
increase the risk of a crash.
For your safety and customer satisfaction, we are initiating a safety recall campaign to inspect the affected drive chain.
What is Suzuki doing to solve the problem?
Your dealer will inspect the drive chain on your 2014 Suzuki DL650A V-Strom motorcycle. If the drive chain has a link that
is not riveted properly, your dealer will install a new chain, and front and rear sprockets on your motorcycle.
This procedure will take approximately two hours to complete.
Parts are available now, and there will be no charge to you for any recall service-related parts or labor.
What you should do:
Make sure you are prepared for the recall service by taking the following steps:
● Before taking your motorcycle to your dealer, contact them as soon as possible to set up an appointment for the
recall service.
● We suggest that you bring this letter and the enclosed card to your dealer to help your dealer process your claim.
Bio je tu i problem sa TPS-om kojeg nikad Suzuki nije priznao i pozvao na opoziv, pa smo kasnije sami morali mjenjati...
Yamaha je na Fazeru imala isti problem, ali su vlasnicima uredno zamjenili :thumbup:
       Eto,neka, nisam cuo...sad znam,nije ni bitno,nees ti greske.,bolje nego dovod goriva i samozapaljenje...  :kava:
Citat: Osy  u Veljača 25, 2021, 09:07:06
Suzuki je smeČe...
korpa, magneti, kapula s prekidaćem svitla, konektori, tps, kočnice, pucanje iz airboxa, uvijanje, privijanje, savijanje....  :smijeh:
Citat: zubakis  u Veljača 25, 2021, 12:06:08
Suzuki je smeČe...
E neka si im reko :smijeh: ;)
Suzuki je smeČe...
Osim pucanja iz airboxa nisam imao ništa od navedenog.Prodao ga s još originalnim akumulatorom.
Citat: Osy  u Veljača 25, 2021, 12:45:46
Sta se ti javljaš BMW je smeČe još i veČe
Citat: zubakis  u Veljača 25, 2021, 14:47:51
Ma Ča si reka.....
tonciv666
Neka si mu reka
Poslano sa mog BLA-L09 koristeći Tapatalk
Citat: Paf  u Veljača 25, 2021, 11:24:26
Ako ti pucanje lanca u voznji nije neki veliki problem, sretno. Ma da, nees ti greske
Bobi se upec'o svjetski.
Daj Bobi koji putopis da imamo sto citati.
