ContiTrailAttack 3
Autor iviccaa, Veljača 11, 2019, 14:09:08
The ContiTrailAttack 3 is a tyre designed specifically for the very latest adventure motorcycles.
•Revised tread pattern, in combination with our latest RainGrip compound, offer exceptional grip in wet conditions.
•Extremely fast warm up times, with your tyre up to temperature within the first mile, even in cold weather.
•MultiGrip Technology improves mileage through a wear resistant central area and progressively increasing grip levels towards the shoulder, with no feeling of step as you lean the bike over.
•Our unique Traction Skin provides an extremely safe and short scrubbing in period. This is possible due to the revolutionary micro-roughness of the tread surface, which is the result of the new tyre mould coating technology which eliminates the need for tyre-release agents.
•Zero Degree steel belt limits tyre growth at high speeds to superb stability, even under heavy braking.
..osim ove samohvale u reklami, imaš li ikakvih informacija o tim gumama, meni su zanimljive
Dodano malo teksta u prvi post.
Ono sto je znacajno:
- guma se unutar 1500m odmah ugrije na radnu temperaturu i moze se gaziti
- profil naprijed 5mm, iza 9mm, dakle dugotrajna
Samo da nevobla kao njene prethodnice. :smijeh:
Nije baš neki Trail profil. Više cesta.... :buahaha:
 :bzvz: ma sve je to isto sranje.....made in PRC! :smijeh:
Toni
Citat: iviccaa  u Veljača 11, 2019, 14:29:23
Evo sam ih narucio pa ce veime pokazati kakve su. To sta se kao ugriju u kilometar ipo mi ne znac puno jer ionako ne gasiram.Triba mi ura ipo da pocmen vozit brze .🤦‍♂️
Nije mi nista.
Iste narucio I moj drugar za GS, čeka na isporuku
Ima li neki znalac da objasni razliku u temperaturi hladne i zagrejane gume u normalnum prolecnim uslovima recimo? ;)
Citat: zander  u Travanj 10, 2019, 18:17:32
Pa vidi ovako, temperatura hladne gume sigurno je manja od temperature zagrijane gume ako uzmeš u obzir temperaturu zagrijane gume koja je sigurno veća od temperature hladne gume. I obratno, ovisi s koje strane gledaš ;).
Razlika je što zagrijana guma topla, a hladna je nezagrijana  :)
...eto :thumbup:. Mislim da mi Ponti možemo raditi na Wikipediji :).
A jes vala pametan...bolji je nego moje "Tenerke"
Zahvaljujem se strucnjacima na objasnjenju.  :ooda:Slatko sam se ismejao. A nista naucio...
