V-Strom 250 L7 [2017-2019]
Autor agolac, Kolovoz 08, 2017, 15:24:06
Engine and transmission
Displacement:   248.00 ccm (15.13 cubic inches)
Engine type:   Twin, four-stroke
Power:   24.67 HP (18.0 kW)) @ 8000 RPM
Torque:   23.40 Nm (2.4 kgf-m or 17.3 ft.lbs) @ 6500 RPM
Compression:   11.5:1
Bore x stroke:   53.5 x 55.2 mm (2.1 x 2.2 inches)
Fuel control:   Single Overhead Cams (SOHC)
Ignition:   Electronic ignition
Lubrication system:   Wet sump
Cooling system:   Liquid
Gearbox:   6-speed
Transmission type,
final drive:   Chain
Chassis, suspension, brakes and wheels
Front suspension:   Telescopic, coil spring, oil damped
Front wheel travel:   150 mm (5.9 inches)
Rear suspension:   Link type, coil spring, oil damped
Rear wheel travel:   160 mm (6.3 inches)
Front tyre:   110/80-17
Rear tyre:   140/70-17
Front brakes:   Single disc. ABS
Rear brakes:   Single disc. ABS
Wheels:   10-spoke wheels
Physical measures and capacities
Fuel capacity:   17.00 litres (4.49 gallons)
.. ha ništa, previše espressa  :smijeh: ;)
Dosada mi je bila extra ružna prednjica od kiklopa, al sad je ova 250-ka stvarno nakaza :thumbdown: Ko je to odobrio neka izvrši harakiri :ooda:
Najljepse izgleda iz pticje perspektive
SirOliver
Ima lipu zadnju lampu
Citat: SirOliver  u Listopad 18, 2017, 17:02:40
Citat: Osy  u Listopad 18, 2017, 16:11:45
Dosada mi je bila extra ružna prednjica od kiklopa, al sad je ova 250-ka stvarno nakaza Ko je to odobrio neka izvrši harakiri :ooda:
Baš tako, kao Frankenstain, sklapali je od delova koje su nasumice skidali sa tavana, pa otuda najviše slici na strašilo Korenko
