K1200rs
Autor indian, Listopad 31, 2017, 09:58:24
indian
BMW K1200rs
Displacement:   1171.00 ccm (71.45 cubic inches)
Engine type:   four cylinder, four-stroke
Power:   130.00 HP (94.9 kW)) @ 8750 RPM
Torque:   117.00 Nm (11.9 kgf-m or 86.3 ft.lbs) @ 6750 RPM
Compression:   11.5:1
Bore x stroke:   70.5 x 75.0 mm (2.8 x 3.0 inches)
Valves per cylinder:   4
Fuel system:   Injection
Fuel control:   Double Overhead Cams/Twin Cam (DOHC)
Cooling system:   Liquid
Gearbox:   6-speed
Transmission type,
final drive:   Shaft drive (cardan)
Fuel consumption:   6,4 litres/100 km (15,7 km/l or 36,9 mpg)
Greenhouse gases:   116.0 CO2 g/km. (CO2 - Carbon dioxide emission)
Chassis, suspension, brakes and wheels
Frame type:   Bridging frame consisting of die-cast aluminium, engine decoupled from vibration through bearings.
Rake (fork angle):   27.3°
Front suspension:   BMW Motorrad Telelever; stanchion diameter 35 mm, central strut.
Front wheel travel:   115 mm (4.5 inches)
Rear suspension:   Die-cast aluminium single-sided swing arm with BMW Motorrad Paralever; central strut, spring preload adjustable to continuously variable levels by means of hydraulic handwheel, rebound damping adjustable.
Rear wheel travel:   150 mm (5.9 inches)
Front tyre:   120/70-ZR17
Rear tyre:   180/55-ZR17
Front brakes:   Double disc
Front brakes diameter:   320 mm (12.6 inches)
Rear brakes:   Single disc
Rear brakes diameter:   285 mm (11.2 inches)
Physical measures and capacities
Dry weight:   266.0 kg
Power/weight ratio:   0.4626 HP/kg
Seat height:   770 mm (31.1 inches) If adjustable, lowest setting.
Alternate seat height:   800 mm (32.3 inches) If adjustable, highest setting.
Overall height:   1,340 mm (52.8 inches)
Overall length:   2,260 mm (89.0 inches)
Overall width:   920 mm (36.2 inches)
Wheelbase:   1,555 mm (61.2 inches)
Fuel capacity:   20.50 litres (5.42 gallons)
Reserve fuel capacity:   4.00 litres (1.06 gallons)
https://www.youtube.com/watch?v=3Y94R7zrVrI
indian
Lijepo izgleda, koje je godište?
indian
Citat: Osy  u Listopad 31, 2017, 10:51:03
2002g. 27tkm- Izgleda dosta dobro i očuvano..
Prespavao je 10g u garazi,.. zadnji vel. servis 2016. ali i dalje nevožen..
Prvi vl. ga je jako cuvao,  tak da  nisam mogo rec ne..  :)
Citat: indian  u Listopad 31, 2017, 10:57:14
Najslađi izgovor za sve u životu... ;)
Citat: fatboy  u Listopad 31, 2017, 11:22:44
..pogotovo ženama  :smijeh:
BTW..čestitam  :thumbup:  ..da ne velim..blagodarim ..jer me osi čeka na forhend   :)
Čestitke
Izgleda stvarno očuvan.. a kilometraža je nikakva..
Puno sretnih i lijepih kilometara!  :moto2:  :thumbup:
indian
 :moto2:  :beer:  hvala! na cestitkama
Super je za vozit,.. iako, skroz jedno novo iskustvo.. :thumbup:
jedna nova dimenzija..
Cestitam :thumbup:
Novo iskustvo i nova dimenzija, kao da slusam sebe ;)
Nizak sic, 770 mm do 800 mm. Neće biti za visoke ljude
Bilo bi pošteno da se u logo ovoga foruma ubaci jer više nismo manjina.
:belj:
Ajmo glasanje!  :)
indian
I ova je ok
Poslano sa mog S60 koristeći Tapatalk
