V-Strom 650 L2-L7 [2012-2017]
Autor Mrki, Siječanj 19, 2018, 19:39:22
Suzuki DL 650 V-Strom
Engine: Four stroke, 90°-V-twin, DOHC, 4 valves per cylinder.
Capacity: 645 cc / 39.4 cu-in
Bore x Stroke: 81 x 62.6 mm
Compression Ratio: 11.2:1
Cooling System: Liquid cooled
Oil Capacity: 3.0 L (3.2 / 2.6 US / Imp qt)
Lubrication: Wet sump
Induction: Fuel Injection
Ignition: Electronic Ignition
Starting: Electric
Max Power: 49 kW / 66.6 hp @ 8800 rpm
Max Torque: 60 Nm / 6.12 kgf-m / 44.3 lb-ft @ 6400 rpm
Clutch: Wet, multiple discs, cable operated
Transmission: 6 Speed
Final Drive: Chain
Frame: Aluminium, twin spar
Primary Reduction Ratio: 2.088 (71 / 34)
Final Reduction Ratio:   3.133 (47 / 15)
Front Suspension: Telescopic, coil spring, oil damped
Rear Suspension: Link type, coil spring, oil damped
Front Brakes: 2 x 310 mm disc, 2 piston calipers, ABS
Rear Brakes: Single 260 mm disc, 1 piston caliper, ABS
Front Tyre: 110/80R19M/C 59H
Rear Tyre: 150/70R17M/C 69H
Rake: 26°
Trail: 110 mm / 4.3 in
Dimensions
Length: 2290 mm / 90.2 in
Width: 835 mm / 32.9 in
Height: 1405mm / 55.3 in
Wheelbase: 1560 mm / 61.4 in
Seat Height: 835 mm / 32.9 in
Ground Clearance: 175 mm / 6.9 in
Wet Weight: 214 kg / 472 lbs
Fuel Capacity: 20 Litres / 5.2 US gal / 4.4 Imp gal /
XT model [2015-2016]
Takozvani model Ružno Pače
Što je, je...prvo ta pichkasta svjetla, a onda kljun...ružan...
Citat: Osy  u Siječanj 19, 2018, 19:45:02
No još uvijek ni blizu GS ružnoći  :buahaha:
Citat: agolac  u Siječanj 19, 2018, 19:46:54
Daaaaa, daaaaa...tješi se :buahaha:
Milanezi
Citat: Saxi  u Siječanj 19, 2018, 19:41:31
Vas dvojica povedite računa šta pričate, da ne padne berba ušiju...
Meni ček i XT model dobro izgleda.. vjerovatno zbog žbica  :)
Milanezi
Apropo poredjenja sa gs-om, slika govori više od hiljadu reči  :tongue:
A evo jedna i sa onim starim stromom, što ima liniju i siluetu kao da su je tesali sekirom  :P
Ko ima oči, ne treba mu objašnjenje  :P
Ja ovdje samo vidim da ti ljeva maglenka baca snop drugacije nego desna
Milanezi
Ne znaš ti, to tako treba, fabrički :)
MotoMachak
Od ove predzadne linije crveni mi je najljepši  :moto2:
